Reaction-Diffusion Equations and Matlab
I want to solve the reaction-diffusion problem, in 2D, with Matlab:
Sum_{j=1}^{4} D_{1j} * (drond^{2}z_{j} / drond x^{2} + drond^{2}z_{j} / drond y^{2}) + R_{1} = 0
Sum_{j=1}^{4} D_{2j} * (drond^{2}z_{j} / drond x^{2} + drond^{2}z_{j} / drond y^{2}) + R_{2} = 0
Sum_{j=1}^{4} D_{3j} * (drond^{2}z_{j} / drond x^{2} + drond^{2}z_{j} / drond y^{2}) + R_{3} = 0
Sum_{j=1}^{4} D_{4j} * (drond^{2}z_{j} / drond x^{2} + drond^{2}z_{j} / drond y^{2}) + R_{4} = 0
Boundary conditions: x = 0,1 z_{1} = 1 ; x = 0,1 z_{2,3,4} = 0
So, I have a system with four partial diffrential equations. and I want to plot the solution for every equations.
What it's wrong in my code ? The plots of solutions must be a surface (almost like a bell), but is not.
CODE --> Matlab
clc;
clear;
close all;
   a=0;b=1;n=5;
   h = (b-a)/(n+1); % step
   I=eye((n-1)*(n-1));
   A11=zeros((n-1)*(n-1));A12=zeros((n-1)*(n-1));A13=zeros((n-1)*(n-1));   A14=zeros((n-1)*(n-1));
   A21=zeros((n-1)*(n-1));A22=zeros((n-1)*(n-1));A23=zeros((n-1)*(n-1));A24=zeros((n-1)*(n-1));
   A31=zeros((n-1)*(n-1));A32=zeros((n-1)*(n-1));A33=zeros((n-1)*(n-1));A34=zeros((n-1)*(n-1));
   A41=zeros((n-1)*(n-1));A42=zeros((n-1)*(n-1));A43=zeros((n-1)*(n-1));A44=zeros((n-1)*(n-1));
   b1=zeros((n-1)*(n-1),1);b2=zeros((n-1)*(n-1),1);b3=zeros((n-1)*(n-1),1);b4=zeros((n-1)*(n-1),1);
   k1=1;k2=0.4;k3=0.5;k4=0.2;k5=0.1;
   % diffusion matrix
   D11=1; D12=-0.43; D13=-0.19; D14=-0.265;
   D21=-0.14; D22=1.475; D23=-0.025; D24=0.235;
   D31=0.105; D32=0.07; D33=1.475; D34=-0.19;
   D41=-0.085; D42=-0.245; D43=0.27; D44=1.17;
   [x,y] = meshgrid(a:h:b);      % uniform mesh
   % Matrix A
   K1D = spdiags(ones(n,1)*[-1 2 -1],-1:1,n-1,n-1);
   I1D = speye(size(K1D));
   Delta = kron(K1D,I1D)+kron(I1D,K1D);
   % A1i
   A11=D11*Delta-(k1+k3)*I*h^2;
   A12=D12*Delta;
   A13=D13*Delta;
   A14=D14*Delta-k5*I*h^2;
   %A2i
   A21=D21*Delta-k1*I*h^2;
   A22=D22*Delta+k2*I*h^2;
   A23=D23*Delta-k4*I*h^2;
   A24=D24*Delta;
   %A3i
   A31=D31*Delta;
   A32=D32*Delta-k2*I*h^2;
   A33=D33*Delta+k4*I*h^2;
   A34=D34*Delta;
   %A4i
   A41=D41*Delta-k3*I*h^2;
   A42=D42*Delta;
   A43=D43*Delta;
   A44=D44*Delta+k5*I*h^2;
   % b
   b1(1)=(-1/h^2)*D11;
   b2(1)=(-1/h^2)*D21;
   b3(1)=(-1/h^2)*D31;
   b4(1)=(-1/h^2)*D41;
   b1(n-1)=(-1/h^2)*D11;
   b2(n-1)=(-1/h^2)*D21;
   b3(n-1)=(-1/h^2)*D31;
   b4(n-1)=(-1/h^2)*D41;
   % aprox solution
   A=[A11 A12 A13 A14;A21 A22 A23 A24;A31 A32 A33 A34;A41 A42 A43 A44];
   bn=[b1;b2;b3;b4];
   ub=reshape(bn,(n-1)*(n-1)*4,1);
   v=inv(A)*ub;
   % split the solution vector
   pas=size(A11);
   v1=v(1:n+2);
   v2=v(pas+1:2*pas);
   v3=v(2*pas+1:3*pas);
   v4=v(3*pas+1:4*pas);
   vv1=zeros(n+2,n+2);
   vv2=zeros(n+2,n+2);
   vv3=zeros(n+2,n+2);
   vv4=zeros(n+2,n+2);
   % boundary conditions
   vv1=[ones(n+2,1) v1 ones(n+2,1) ones(n+2,1) ones(n+2,1) ones(n+2,1) ones(n+2,1)];
   vv1=[zeros(n+2,1) v1 zeros(n+2,1) zeros(n+2,1) zeros(n+2,1) zeros(n+2,1) zeros(n+2,1)];
   % plot
   figure
   set(gcf,'DefaultAxesFontSize',8,'PaperPosition', [0 0 3.5 3.5])
   subplot(2,2,1);
   surf(x,y,vv1);
   title('Numerical solution for Ecuation1');
   subplot(2,2,2);
   surf(x,y,vv2);
   title('Numerical solution for Ecuation2');
   subplot(2,2,3);
   surf(x,y,vv3)
   title('Numerical solution for Ecuation3');
   subplot(2,2,4);
   surf(x,y,vv4);
   title('Numerical solution for Ecuation4');
RE: Reaction-Diffusion Equations and Matlab
makes no sense to me, and you don't seem to do anything much with vv2 etc
Cheers
Greg Locock
Hi Greg,
Thanks for your reply.
I think my issues start when I try to split the big vector v, into 4 small vectors (one for each equation:v1,v2,v3,v4).
After that, the boundary conditions(vv1,vv2,vv3,vv4) is not correctly implemented (it's need to be created dynamically).
In conclusion, there is a size issue between:
- [x,y] = meshgrid(a:h:b);
- split the vector v
- surf(x,y,vv1);
But, I don't have any idea to resolv the issue.
Cheers,
George Sarbu
Frankly I'm amazed it runs at all
v2=v(pas+1:2*pas);
pas is a 1x2 matrix, what do you think that line is supposed to accomplish? I suspect that you really want
v2=v(pas(1)+1:2*pas(1));
doubtless there are similar problems with array sizes later on
Cheers
Greg Locock
I make some changes:
CODE --> Matlab
pas=size(A11);
v1=v(1:pas);
v3=v(2*pas(1)+1:3*pas(1));
v4=v(3*pas(1)+1:4*pas(1));
for i=1:pas
  vv1(i,1)=1;
  vv2(i,1)=0;
  vv3(i,1)=0;
  vv4(i,1)=0;
end
vv1(:,2)=v1;
vv2(:,2)=v2;
vv3(:,2)=v3;
vv4(:,2)=v4;
for i=3:pas
  for j=1:pas
    vv1(j,i)=1;
    vv2(j,i)=0;
    vv3(j,i)=0;
    vv4(j,i)=0;
  end
end
Now, if I take h very small: h = (b-a)/(n+10), the surf function run well. But, of course the plot is not like a bell :)
Sadly I don't have the time to figure out what you are actually tying to accomplish (the first 4 lines in your first post don't actually mean anything to me) so all I can suggest is to break the problem down into small parts, check that each step works, including the sizes of the arrays, at each step.
Cheers
Greg Locock
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
