Recently, I ran across an old removed "dumb" Rosemount DP xmitter (didn't get the model number) with only a zero and span adjustment on the outside of the xmitter housing. I was wondering if this type of old transmitter allowed the entire range to be shifted via the zero adjust? In other words, if the instrument was originally set up to read 0-100 in/h20 with 4-20 mAdc out, could the zero be shifted to provide for a 20 mAdc out at 0 delta p? Maybe for use in a wet leg type application or something similar.
Also, if the range could be adjusted (swapped)in this manner, would that mean that you would then use the zero as a span adjustment and vise-versa - since 20 mAdc would then equate to 0 delta P, or would the normal zero/span convention still apply?
Thanks.
Thanks.
