The code check is the same in the current 8.1 (soon to be 9.0) version of RISA. But, there is a good explanation.
There is a minor hole in the AISI code checking procedure. At least, it's a hole if you want to say that one of te combined stress equations governed.
RISA always gives a combined stress equation as the governing equation. But, in this case, there is only on one moment in the member at the controlling location. The maximum moment occurs at the mid span where shear force is equal to zero. There is no weak axis moment, there is not torque, there is not axial load.
Therefore, the most correct value for the maximum code check at that location would be a simple Mu / PhiMn, right? Well, that's what RISA is reporting.
The only problem is figuring out what equation to list as the governing one. In their combined stress equations AISI always squares that bending term or puts a 0.6 multipler in front of it. So, those would technically result in a slightly lower code check.... but, a code check which would be misleading.
Therefore, RISA prefers to present the more accurate code check.
