Don't want to get into theory...very specific question here. Have a metal building with purlins on top of main frames- presumably only minimally connected to the top flange of the main frame beams at about 4 feet oc. Thinking that the unbraced length for positive flexure (top flange in compression) would be 4 feet. If I were to weld plates to the webs at each purlin location (connecting bottom flange to top flange), would the unbraced length for negative flexure at the columns and at center for uplift match the unbraced length for positive flexure? I'm thinking no, since translation/rotation of that bottom flange would be dependent on the connection between the purlin and the top flange of the beam.
