I am installing (3) 2400/120V VT's which will be Y connected, for metering, and have a concern about grounding. Is it good practice to ground the Y point of both high and low voltage windings? Is their a concern of an alternate zero sequence path with the HV grounded? Will leaving the HV Y point float present any problems - metering/relaying? I have seen both configurations used. The system is on an IPP generator (Delta Connected Induction) with a Y-Y step up transformer.
