X,Y,Z BOUNDING BOX
  • Thread starter Thread starter rickkiefer
  • Start date Start date
R
rickkiefer
Guest
I am looking for a way to have a part get the overall x,y,z and put into BOM. Anyone have any idea's on how to get this done. It really is hard when you have to go back into a 4000 component assembly and measure each part and manually input these parameters in.
Rick
if u happened to have created each part from a block. and only made the
block 1st. then xyz would be sd1, sd2 and sd3 but this is extremely
unlikely. :) ur looking @ a bad weekend doing it manually.
but next time you could save urself some time and set a
parameter for each, then u could easily add this to ur bom table.
