X-Y ploy for a big model
Chen1
Geotechnical
Jun 29, 2013
108
Hello Everybody,
I know how to draw X-Y data like Stress-strain curve, however my model is very big, so I can not select the whole model because the number of elements is very big, I need to divide it into smaller parts. I found that i need to divide my model into 25 parts, then extract the X-Y data for every parts then combine them to get the final X-Y curve.
This is a tedious process. Is there any idea about extracting
you can use python scripting to extract the data, other than that I don't know (the limit is indeed too low, i haven't found a way to change it)
Hello Sdebock
i want to draw the stress-strain curve. Can you teach me how can i do that using python. I am not very familiar with pyhton. So i wish you could give me enough information.
Sdebock
I sent you a very simple input file, i need to draw the stress-strain curve (S33-LE33) for the coal-1.coal. This model is just uniaxial compression test.
my original model is similar to the model that i sent to you, however the dimensions are much bigger and more finer.
Please Help me with the stress-strain curve, right now i am reading the manual.
Thank you so much.
 http://files.engineering.com/getfile.aspx?folder=dfa8eadf-f920-4ec8-9e84-4f3776a05ffe&file=test.inp
Hello Sdebock,
Please help me, I sent you a simple model which is similar to the original big model, and i need to draw the average S33-LE33 for the coal-1.coal set, As i told you i know how to do that for small model, however for a big model, i should use python, but i did not study python before, i am reading the manual now. please help me.
Thank you.
Is there any idea, please help me. I need to draw average S33-LE33 using python. Thanks
