If somebody has a conceptual idea of the following situation, please let me know:
1)
A vessel is designed, fabricated and tested under the concept of X-ray exam. exemption in flanges to nozzle neck weldments for less than NPS10 nozzles (although the specified X-ray by customer was 100%).
I understand that unless the customer clearly states that all nozzles has to be x-rayed, you can use the above mentioned exemption.
2)
Suddenly the customer, by his own, decides to x-ray the nozzles, finding in some of them some defects he considers not acceptable. And of course wants to repair them.
Should this repair be consider as an additional under $$ concept because the vessel was designed without X-ray exam.?
3)If he decides to UT nozzle to shell weldments, although this NDT was neither specified nor required, should the defects -if any- be repaired with no cost?
This is happennig to us, so I would like to know if some of you have ever faced this situation and how solved it.
Thanks in advance
Juancito
1)
2)
Thanks in advance
Juancito
