I've supplied several motors on a project (in USA) that utilizes a delta power system. Most/all of my low hp motors appear to be wye wound. The client believes all motors must be delta wound for use in a delta power system.
Their reasoning is that when a wye only wound motor is connected to a delta power source, it carries only 67% voltage across the winding, providing less horsepower. Under full load operation, the motor is more likely to fail.
Can a wye wound motor can be used in a delta power supply? Why or why not? Thank you.
