You'll kick yourself when you see how easy it is. This is very powerful, but there are some restrictions on what you can do inside a function, as usual it seems to be a case of suck it and see.
Go into the VBA task (under Macro), insert a new module, type in your function, go back to your spreadsheet and use it!
Here's the blurb from the help file:
This example uses the Function statement to declare the name, arguments, and code that form the body of a Function procedure. The last example uses hard-typed, initialized Optional arguments.
' The following user-defined function returns the square root of the
' argument passed to it.
Function CalculateSquareRoot(NumberArg As Double) As Double
If NumberArg < 0 Then ' Evaluate argument.
Exit Function ' Exit to calling procedure.
Else
CalculateSquareRoot = Sqr(NumberArg) ' Return square root.
End If
End Function
Using the ParamArray keyword enables a function to accept a variable number of arguments. In the following definition, FirstArg is passed by value.
Function CalcSum(ByVal FirstArg As Integer, ParamArray OtherArgs())
Dim ReturnValue
' If the function is invoked as follows:
ReturnValue = CalcSum(4, 3 ,2 ,1)
' Local variables are assigned the following values: FirstArg = 4,
' OtherArgs(1) = 3, OtherArgs(2) = 2, and so on, assuming default
' lower bound for arrays = 1.
Optional arguments can have default values and types other than Variant.
' If a function's arguments are defined as follows:
Function MyFunc(MyStr As String, Optional MyArg1 As _ Integer = 5, Optional MyArg2 = "Dolly"
Dim RetVal
' The function can be invoked as follows:
RetVal = MyFunc("Hello", 2, "World"
' All 3 arguments supplied.
RetVal = MyFunc("Test", , 5) ' Second argument omitted.
' Arguments one and three using named-arguments.
RetVal = MyFunc(MyStr:="Hello ", MyArg1:=7)
Cheers
Greg Locock
