Hello all,
Upon testing some electro-polished metal test specimens, axially and in tension, the smooth electro-polished surface changes dramatically to a wrinkled or textured surface, why?
I can't seem to find anything that explains this effect on the internet, including academic papers and these forums. It is likely that I don't know the correct terminology. My guess at this point is that the change is due to the grains deforming/twisting/slipping and thus disrupting the originally smooth surface. References to papers or other resources to help explain this effect is most welcome.
The parts are small, roughly 0.2 mm square cross section and are cut from tubing with a 3 mm outer diameter. The material is 316 stainless steel with a grain size print call out of > or = to 8 per ASTM E112.
A picture is attached to illustrate. The tab (on the left) shows the original surface while the small area (on the right) shows the deformed surface.
Thank you for any help you can provide.
acspain
acspain
