Would you ever do a structural assessment of a building in "bad shape"? 8
Ben29
326
Bad shape = 170 years old, 1-story brick masonry bearing wall building with steel roof trusses, partial roof collapse for at least 8 years, open to the weather, tree growing inside building, etc.
If you were going to do an assessment on this building, what legal precautions would you take to protect yourself?
Just did a pair of them last month. I treated it like any other structural assessment. I have standard language in my proposals/contracts to cover inspections:
Inspections. Inspections of existing structures are intended to assist Client in evaluating the overall condition of the structure. It is based on observations made by <> of the visible and apparent condition of the structure and its components on the date of the inspection. In the conduct of the inspection, <> has not disassembled equipment, moved furniture, or opened interior finish or exterior façade coverings. Although care has been taken in the performance of any inspection, <> makes no representations regarding latent or concealed defects which may exist. Reports prepared by <> are not fully exhaustive, nor do they imply that every component was inspected or every possible defect discovered. <> does not warranty or guarantee the condition of any part or component of the structure.
pharmENG,
Thank you - I have very similar verbiage on my reports and proposals. Thank you for the validation that other engineers aren't necessarily shying away from this type of work. I am just a little more concerned/cautious after the Surfside collapse, in terms of taking these type of jobs.
A lawyer once told me not to use the word "inspection", rather, use the word "review"
Ben, I think there's a bit of a difference between an abandoned building with a collapsed roof and a building with several hundred occupants. When I do an occupied building, I put reminders on my calendar to follow up if I find something seriously wrong. If they haven't taken adequate action in a time frame that I deem appropriate, I call the AHJ and inform them of the unsafe condition. I don't make many friends that way, but that doesn't bother me.
XR - I'd be interested in knowing the rationale behind that.
Ben29 said:
Bad shape = 170 years old, 1-story brick masonry bearing wall building with steel roof trusses, partial roof collapse...
I'll suggest you pass on this one. Roof trusses c. 1850 (170 years old) were definitely not steel. Even wrought iron for structural use was high-tech in the 1850s... and this building definitely has roof problems. My point is, "The devil is in the details"... and you have to be right.
Most likely, the building << 170 years old. However, age remains critical, allowable structural properties changed with time. In this case, if the roof trusses are assumed to be "steel" and they are actually "wrought iron" you will over estimate their allowable loading... and not know it.
pham - Review might imply that you ran calcs or checked the area in some other way than visual inspection. I usually use the wording, "in the observed areas", or "it appeared".
GC - XR's post says the lawyer said to use review and NOT to use inspection. I specify 'visual' and use the same wording you have. Maybe I'll check with my broker and see if they care.
Oops... misread it. I would be interested too.
Ben - Maybe you can note Slide's concerns in your report along with the condition of the truss and push for them to be replaced. Or keep the truss for aesthetics and go with a new structural roof system
The liability aspect is indeed important, but I would also consider if you really want to take this on. If it looks like a case where the structure is to be demolished, fine, but if it is to be repaired it is a very different situation. The repair of buildings like this are not for the faint hearted. Inevitably you end up involved in an endless number of problems where engineering judgement is required or your client does not appreciate the complexity of the question they are asking you. I have done many reviews or 50's vintage buildings and it added a great deal of stress during the construction time.
Our insurer has many guidelines about the use of the word "inspection." I pasted an excerpt from our insurer guidelines.
XR250, I heard that many times from an old employer and I still follow that guideline. I think the word inspect carries some weight as it might infer that you are certified to inspect certain aspects of construction. I also use the word "observe".
Looks like Brad beat me to it.
Sliderule is correct, the trusses are iron.
Sorry, I have to ask. Why ? Surely you're going to 'doz this wreck ? Maybe some of the building has historical significance and people want to salvage the "bricks and mortar" and rebuild the timber components. Then it would be inspection of the mortar and such ... sorry, "review", "cursory review" ...
I have a few times... only one was so bad that I asked the building inspector to remain outside in the event he had to call 9-1-1. I was young and foolish back then, you know 10' tall and bulletproof...
The assessment is that the building is unstable because the masonry walls aren't stabilized by the broken roof. You can't get sued for saying that.
On a serious note, I would create a table of all the structural elements in the building on one side and all the "observations" on the other to force myself to think critically. For example, Foundations: not observed, but no signs of wall cracking indicating distress. ...assumes no liability for unobservable conditions.
So if you have all these "I'm not responsible if anything goes wrong" in your contract, what exactly is the client paying you for?"
I just want to understand what exactly are the engineer's responsibility or any liablity on the engineer's part when you do evaluation like this.
The client is paying for what a "prudent professional" would do in the circumstance. Or at least that is the way the courts would look at it.
If it is impossible to ascertain the residual strength of a given assembly via visual review (almost always is), and that was what an engineer was asked to do, they would not be derelict for issuing a report with such qualifications. That said, if a visual review could have or should have given the "prudent professional" an indication that more testing was warranted then they would be liable for not instructing their client to perform said testing should something happen.
While courts can interpret what a "prudent professional" would do in an unrealistic manner at times (read: without budget constraints), they are not wholly unreasonable. That is, if something cannot be determined without superman like powers then they wouldn't say a prudent professional should have determined it on their walk-through. That said, I would be very, very careful of saying one did a "cursory" review or something of the sort. A prudent engineer does no such thing. They may not look at everything but for the things they do look at, they are expected to look in detail at least as much as is possible given the information available.
CWB (W47.1) Div 1 Fabricator
Temporary Works Design
The engineer isn't liable for the building. The engineer is liable for the report and specifying required repairs per the Existing International Building Code. That would produce an acceptable report, but a better report will notify the building owner of risks due to unknowns and methods of risk mitigation.
yes, "cursory" smacks of unprofessional but if your quote to the customer says "for $X I'll review the structure for only a couple of hours or $Y for a week's review" then that is what was purchased and I don't think the courts should say "you should've spent Z hours to uncover the deeply hidden faults". The client is buying a specific service and "should" understand the limitations (because you've described them to him, and given him the opportunity to ask questions) of what he is buying. I mean you won't do a soils analysis to fully understand the state of the foundation (will you ?), but maybe you can detect major issues from a visual inspection ??
If this building is so derelict, really is the any option to 'dozing it ? Maybe there something very targeted worth saving.
