Hello.
I still get difficult to work with STL files on NX.
For example get this "simple" file:
How would you convert it to a native NX body?
Rapid Surfacing needs the user to select many point on the faceted body and can be tedious and many times doesn't offer the expected results.
Fit Surface ... you can see the result.
Other options such as Decimate, Subdivide, Smooth... don't produce a result easier to work with either.
Most commands don't accept faceted bodies at all.
What is the best/easiest method to convert STL files like this to something else to work with?
