Working with a Prominant Gas Field
Ilkley Automation
NZ
Working with a Prominant Gas Field operator who was using Trunnion Mounted Ball Valves on Pot Carb (Benfield Solution) spent 4 months on a new approach is there anyone out there suffering from Badly jammed or Corroded Trunion Mounted Ball Valves?
Please advise of your issue with relevant detail so the forum can address it.
Per ISO, only the term Safety Valve is used regardless of application or design.
