Hi, I am using ANSYS Workbench v11. I have an imported model from NX6 with defined parameters such that I can change the dimensions of the part in Workbench. I want to do a DOE so I need to be able to change the parameters in batch mode. I have been trying to find the APDL code of the commands I input into Workbench but so far have not found it. I already read in the manual that you cannot record macros in Workbench. How can I find or generate the command file for the Design Modeler? Any help will be much appreciated. Thanks.
