Wood Design
- Apr 19, 2019
- 2
I am working on a excel sheet to calculate member CSI's for a wood truss per ANSI/TPI 1-2014.
Dose anyone have any worked out examples of truss design calculations that are worked out and follow ANSI/TPI and not just NDS?
Or maybe can help clarify some things out of ANSI/TPI 1-2014 for me:
1)
Regarding the "buckling design value, Fce" equations on page 58. I feel like the second equation, the one for FcEy, should be using Lu and not L' as described to do in the table on top of page 56. And that Lu is the actual length between top chord purlins as shown in Figure 7.2-2 on page 57.
2)
Regarding equation E7.2-1 for calculating the K factor on page 55. If you have a truss with only 1 top chord panel (no adjacent member) the K value will always = 1.0. Or should you use the member on the other side of the truss peak in this case? Should you always be considering the member on the other side of the peak? Any light that you could shine on any of this would be helpful.
1)
2)
