structuresguy
I am wondering what everyone uses when designing the connection of wood trusses to the main structure: Component & Cladding wind pressure or Main Wind Force wind pressures?
My personal interpretation is that the top chord of the truss would be designed for C&C loads, but the bottom chord and webs would be designed for MWFRS loads. I came to this conclusion after reading the commentary in ASCE7-98. It would then follow that the connection of the truss would use MWFRS loads, which results is a large difference for uplift loading. I live and work in Florida, so this is critical for me. Sometimes, it is very difficult to make a connection work using C&C loads. This was always a source of discussion amongst my co-worker, so we used C&C loads typically.
However, I recently discovered that the Wood Truss Council of America has taken the position that truss reactions be based on MWFRS, as well as the design of webs and bottom chords. So they are interpretting the ASCE in the same manner as I am.
Any thoughts, or code requirements, which you may contribute are greatly appreciated. Thanks in advance.
