I would like to know if anyone can recommend a reference that provides design information for a wood shearwall anchor bolt (bent bolt or chemical anchor) into a solid-grouted CMU foundation wall (with concrete footing), that accounts for the interaction with the vertical steel in the foundation wall. The reference I currently use is Section 2107.2.3 of the 2000 IBC (similar to ACE 530 Section 2.1.8.6.1.1 except that IBC has a minimum splice length of 15" instead of 12"
. I'm not sure if this is the best, or most applicable, reference to use for this type of connection.
