Assuming there are both flush in the floor - IF there is a nailer plate bolted to the top of the W8 AND that is level with the top of the LVL, you could use a top flange style hanger.
That W8 is 8" wide so maybe a little torsion on it so... make sure it can be resisted. If not, a version of JAE's clip angles could work if attached to the W8 web and sufficient bolts thru the LVL to resist the slight moment of the connection eccentricity.
