We have had our RotoAlign Pro for a year now. Last year I rented the BoreAlign tool twice and measured bearing bores of an Ingersoll-Rand 82KVG frame that we had just regrouted, and then measured the bearing bores of an Ajax DPC-600, that we crashed some con-rod bearings in. We also received one demonstration free, where the salesman came and showed us how the BoreAlign worked and showed me how to operate it. That was on an Ingersoll-Rand 26KVG. Of course the crankshafts were out of the units all three times. In the first two cases, the other recip compressors in the building were still operating, and in the demonstration we had to deal with drafty cold winds in a heated building. The KVG’s were done with the just the bottom half of the bore, while the Ajax had the caps in for a complete bearing bore.
I believe the more accurate tool is called CentrAlign. Ludeca is the US importer of the tool.
I have three digital pictures of the 82KVG and a PDF of the basic report that I printed out that I could send you via email.
You are correct about most of the operation. The target is rotated in the bores and the laser is stationary outside the unit. I used the oil pump flange which spaced the laser about 12” from the nearest bearing bore. The wheeled cart you spoke of, is actually the magnetic base for the rotating point on the mast you talked about. The target is mounted on a spring loaded holder, which pushes a rod out against the bearing bore. The rod will touch down on several points. You basically have an inside mic, that is constrained to rotate about a point somewhere near the center of the bearing bore. The computer then computes a bore center line. You can see all the data points as you take them as well as the averaging the computer does. Thus the tool operator can see an out of round bore.
For accuracy, I tested taking the target out of the bore in between sets of measurements to see how well the sets of measurements compared. I also reconstructed the mast when working on the 82KVG, and the measurements before and after seemed to agree well. The vibration was a problem. The 82KVG was 14’ long with 8 bores. At the #7 and #8 bores, I had to use the maximum averaging of the computer to get results with lower standard deviations. I felt that a standard deviation that was .0005” when I wanted my resolution to be .001” was acceptable. The older sensor that I rented, may have contributed to the vibration problem. You must be careful with thermal growth of the tool as I fought with high radiant heat sources and cold drafts. On the 82KVG I compared the results to a machinist boring bar, and it seemed to be accurate. In the vertical plane, one bore was .0014” high, and another bore was .0019” low. The horizontal plane had one bore +.0016” and another -.0014”. These measurements were from a line of best fits and of course the ten-thousandths accuracy must be taken with a grain of salt considering the standard deviation of my measurements. The crankshaft web deflections also agreed with the measurements we made.
Overall the tool works well for us. I will try to train one of our mechanics this summer on its operation, which I think will go well. The higher order math is done by the computer and data doesn’t need to be transferred from a pad to computer. Bucking the laser in, seemed really simple to me. Unfortunately I cannot compare directly to the wire-line method as I have never done it. However, as the wire line method was described to me, the laser makes some of the measurement and interpretation simpler.
If you are thinking about this option, renting the tool worked well for me. Perhaps the salesman would be willing to give you a demonstration also. Hopefully this doesn’t sound too much like a sales pitch, because it is just my experience.
dwedel
Hotrod Big Engines!
For site policies and guidelines
see faq731-376
