Window size and position
squint305
We use Microstation version 05.07.01.22. I have a dual monitor setup while some people have a single monitor setup. So when I open DGN's other than the ones I setup the window sizes are all wrong for my display. I was hoping someone might be able to point me in the right direction with a keyin, macro, or a configuration setting that I can change in order to resize and position the windows according to my preference.
Thanks for any help you can offer,
Tommy
Check your display settings in windows, under settings you have the ability to change your configuration setting to accomadate your monitors. Hope this helps some
Namdac
Thank you for the suggestion. I didn't think to mention that I use microstation across both monitors. The keyin, macro, etc., I'm refering to would resize the views in microstation window 1, window 2 and window 7. I'm just trying to save myself some time and trouble by using a macro instead of having to drag the window/view to the proper location and then resize the window/view manually. It only becomes a bit of a hassle resizing manually when I QC a lot of DGN's per day. Here are some before and after pics of what I'm wanting to do:
Before:
After:
Thanks,
Tommy
