I have a question for anyone who works on smaller engines which you'd see in small business jets. Is there a constant geared ratio from the blades to the shaft which the generator is attached to in a typical turbine? If so, if a turbine is windmilling in a strong wind in the opposite direction of normal rotation the generator would rotate backwards at the same ratio also. This presents a possible problem for an idea I'm working on. I'm wondering if there's typically some disconnect device.
(This is for an idea I'm working on for a torque-ripple reduction device, but that's a big big different topic for another thread. I don't know anyone who would let me mess with their Citation so it's hard to get info.)
thanks
thanks
