I'm currently looking at the loads subjected on the Main Bearing in a Wind Turbine. I have completed the calculations as per IEC 61400. This has allowed me to calculate the Axial load, Bending moment and torque of the shaft.
I have to calculate the Radial Load, which I have done using the equation RL = Torque/Shaft Radius. However the figure I am equating is a radial load of 3MN, which seems far to high.
Is this the correct equation to use?
If not, what should I be doing?
