Redact
- Aug 9, 2021
- 3
Hi there, I need some assistance :
I need to design a foundation system for a standard 20’ shipping container. I am thinking of just putting in 4 pad foundations for each ‘foot’ of the container with ground mounted twist locks anchored into each foundation.
I don’t have much experience with wind analysis and structural behaviour of systems, so I would appreciate any help you can give.
The attached document shows the calcs for the wind load, I am using the Canadia approach because that is the only one I had reference material for.
I am assuming a wind speed of 150 mph ( 67 m/s) as the container is in a hurricane prone country.
The lateral loads that I am getting are quite high, which is why I would appreciate any comments on whether I am doing the wind analysis correctly.
I also have a question for how the 4 separate pad foundations will behave. I am trying to understand how they will work together. I am assuming there would be pressure on the windward wall and the leeward wall, causing the container to be pushed in one direction as a worst case.
As a result, this is causing a high sliding force. Is my assumption of sliding wrong? Does the frame of the container change the structural behaviour causing sliding to not be an issue?
Same with overturning. As the top of the container has a frame, it is essentially propped. Is overturning no longer an issue? What is the structural behaviour of the group of pad footings?
Any help would be appreciated.
