Wind Load on Conical Roof
Flexural23
14
Anyone have some good documentation pertaining to calculating wind loads for Conical Roofs? Preferably following NBCC, but any would do.
Thanks!
I have not seen provisions for a conical roof, but perhaps a rational approximation with a domed or hip roof?
Use a round column of that actual height, or 80% of the actual height to be a bit more liberal.
A domed roof would only be right for a cone as high as it is wide, but a round tower wind loads will apply the conservative solution (higher load). Theoretically, a cone has half the projected cross-section of a cylinder - but as an approximation, you can justify the 80% height rule as reasonable.
why not to divide the cone height in layers and consider each layer as a round column with decreasing diameters ?
@allgoodnamestaken's suggestion regarding using a hipped roof seems a reasonable one. Maybe you could further modify the tributary zones' pressures by multiplying by the circular profile coefficient?
Dave
Thaidavid
