1. I have a glass canopy with steel structure which is fixed to the first floor slab of the building. The total building height is more than 100meter. But the canopy height from the ground is 5m only.
How can i get the net pressure coefficients for the canopy in this case? ASCE-7 provides provisions for buildings with h<18 meter. But in my case h is greater than 100meter. Why the code does not have the provision for this case?
2. Coefficients for overhang of the roof is what you guys consider in the above case? But even that case is limited to h<18 meter. There is no overhang coefficients for h> 18 m (correct me if i am wrong. I believe so).
Also if we are following the overhang coefficients , what height will you consider to determine velocity pressure? The roof height or the canopy height from ground? It seems like the code says roof height as the figure is for roof overhangs. (Again correct me if i am wrong ) but this does not seem logical for lower canopies !! Same wind loads on canopies at ground floor and canopies at 50th floor ????? Can i use the height of canopy only?
Thanks in advance !!!!
