I was told to design some purlins by a senior engineer that must be Stramit Z250-15 at 1500 centres. These things are spanning 11m and after a few checks I find they fail under the wind pressure from AS1170.2(the Australian wind code), no big surprise. I go back to the engineer and report what he needs to get it to work and he rejects it. He proceeds to tell me that the wind code is unrealistic and I should "reverse-engineer" the purlins. So here's the question, what wind code does give realistic pressures and what's you view on AS1170.2 (if you're familiar with that code)?
Paul
Paul
