abusementpark
For typical diagonal wind brace connections into beam-column joints, I have often seen where people recommend for you to modify the workpoint so that it occurs at the intersection of the outside edges of the beam and column, instead of at the intersection of the beam and column centerlines. This is said to result in a more economical gusset plate and it also avoids having to design the beam to column connection for a transfer force due to the brace load. However, it introduces additional moments into the beam and column, which have to be accounted for in the member analysis.
Does anyone use this method? If so, how do you account for the additional moments in your analysis?
I use RAM Structural System and RAM Connection and haven't found a way to do it.
