I'm in the process of writing a report on a winch drum failure. Our winches are wrapped around the drum and then terminated with a u-bolt on the flange of the drum. The customer is stating that the cable slipped out from under the u-bolt. This may have happened but I want to know how I could estimate the force required to do this. The question really comes down to the number of wraps (not layers) on the drum itself. The more wraps the less force is actually exerted on the u-bolt. I'm estimating that there were 3 total wraps on a 5" diameter winch using 3/8" cable. I know this is a loaded question where many outside factors could come into play, however, I'm just trying to understand the basic math behind the idea. Any thoughts?
-Thanks
-Thanks
