Do you even see the printer on the new computer?
Do you still have the old one or access to it?
Did you copy across the plotter config directory from the old to the new?
The old computer would have had the variable UGII_SDI_SERVER_CFG_DIR set to point to the plotter config that was working.
You would have to copy that to the new system and set the variable to point to it.
If you don't have the old computer then you will need to start over to get the configuration working.
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
