kcourtema
- Jan 13, 2005
- 3
I'm hoping that someone here can help. I have a customer that wants me to do a project in Solidworks 2003. I have installed it but I'm having an issue where once I render anything and try to dynamically rotate it, the entire system freezes. I can't even use ctrl-alt-del to get out of it. It usually only takes 10-15 seconds of continual rotation to cause this to happen. I have tried several part files as well as assy files with no difference.
I actually had 2004 installed several months ago and had the exact same problem. My hardware is more than up to the task: Athlon 64 939pin +3200 on an Abit AV8 with 1/2 gig of ram and an ATI Fire GL T2-128 video card. I have been current with all drivers and I have tried the ATI certified drivers as well as the most curren ones.
Has anyone else had this problem? Any help would be appreciated.
