Why draft does work with suface having open boundry ?
  • Thread starter Thread starter sureshal
  • Start date Start date
S
sureshal
Guest
Hi all,
The draft feature used to apply for only suface having closed boundry. May i know why draft fails for suface having open boundry ?
Suresh.A.L
Hi
yes, it's work only for closed surfaces
but you can caped the surfaces, ... or it's too complex shape?
good luck!
adicar@home.ro
maybe make a small sweep with degree, and after that extend & merge, I guess, I don't know your shape
Hi..
Thanks for your reply.
I was just wondering about the logic behind it .
I used to make a caped surface and later trim it after giving draft.
Suresh.A.L
I don't know the logic, must be one, it's closed any gate to make dirty model (:-:).
I usual don't use draft surface, I prefer to make a strong solid model,also it's better if you have many revisions for model.
Hi Adicar;
The draft in surface will be very much usefull in Pro/Mold to create parting surface.
Suresh.A.L
