Who makes the highest flow CNG injectors?
mymomo
Hi All,
I am having trouble finding CNG injectors that can support over 100HP/cylinder or 75 lbs/hr @7000RPM ? I am planning on running 8-10bar of line pressure. Are there any off-the-shelf injectors available? Thank you so much!
Hehhe..I was going to say "Woodward probably has the largest" bu then I clicked the link and discovered it had already been said. 100hp/cyl doesnt sound like a very big need though...I think Woodward cover some 500hp/cyl engines too.
Curious that the link says the max flow rate is 2.5 g/s at 8 bar but the flow curve clearly shows something over 3 g/s at 8 bar.
I didn't look at the link, but could be a conversion factor between N2 and CNG.
"Schiefgehen will, was schiefgehen kann" - das Murphygesetz
Mymomo, This does not sound like a regular production application.. is it?
