where to get power pole? 3
maxPE
Nuclear
Feb 1, 2003
21
Im having a tough time finding a source for power poles. 40ft. Internet search doesnt turn up much for a "power pole" querie. Im in So CAl. I have located some used poles but am concerned about grading them. Is there a standard for grading so I dont buy pig in a poke?
Max PE ME
Ask Edison or DWP for a 1 or 2 of their vendors. That explains 4800V. You might search for someone familiar with G.O. 95 to keep you tit out of the wringer regulation-wise. The work is essentially outside of the typical NEC scope.
mr busbar. you suggested previously that I should be carefull in selecting used transormers. Any advise on same
OK, suggested is the work be done by a licensed electrical contractor with poleline experience. I don’t think the utility providing the 480V service at the property boundary is going buy into your plan without an electrical inspection on the circuit(s) and equipment [pump, controller, transfomer sets, line with grounding and guying, cutouts, arresters, disconnecting means, LV service entrance, et cetera.] Even in Muleshoe County, the local inspection authority will probably want to see some engineered construction drawings {maybe with a PE stamp} and accept the design before anyone picks up a shovel. No personal offense intended, but it sounds like you may be in too deep before the work is even started.
One reference for transformer testing is Chapter 5 of A.S. Gill’s Electrical Power Equipment Maintenance & Testing.
yp.yahoo.com yields number of hits for 'wood preserving'.
It would be a good idea to get a "Linemans Handbook"
Are you looking for wood or concrete? There are several manufacturers of wood poles in East Texas and Louisiana. Search for "southern pine creosoting" or "creosote company". I used to frame the bare timber per utility specifications prior to pressure treatment at a creosoting company in my youth. If you're in So-Cal looking for a treated wood pole, have you considered the environmental impact? All the treatment material I've been subjected to is nasty.
