Where is the intellisketch menu?
PatCouture
CA
I'm beginning to work with Solid Edge V14 and in the tutorials they say that the Intellisketch command is in the Tools menu. But I've checked all the command menu and there's no Intellisketch command to choose. Does anybody knows what's the problem with me?
Patrick
Intellisketch is only used when sketching.
Either open a new sketch or profile. The difference being that a sketch is called a sketch when created with the sketch command. A sketch is called a profile when initiated with a protrusion or revolve type command.
Once you are within a sketch or profile, you will see the intellisketch command in the tools menu.
--Scott
Thanks you very much Scott
I haven't thought about it!
Pat
