When to utilize Caesar's liberal stress allowables?
jseag
Petroleum
Hello all- there's a good amount of info on WHAT caesar's liberal stress allowable check box is doing in terms of the calculations. My question to those in the pipe stress industry is WHEN do you use this vs not using this? My company has taken the approach to essentially never utilize the liberal allowables. I'm curious if that is consensus thinking and if not, when you are comfortable using the additional "liberal stress" values? Thank you!
Unchecking the liberal stress allowable (sustained stress margin) as a default procedure creates a simplifying uncertainty factor in your expansion stress analysis. I suggest checking this box (and documenting that you have done so) if there are no other reasonable ways to get passing results; based on your confidence that you have considered all possible operating scenarios, the consequent stress range, the expected life cycle frequency, the potential for creep and ratcheting, and that exceeding yield stress in some locations is acceptable.
Basically the only reason its still a checkbox/toggle is some clients/industries have very old specifications that specify you must use the "conservative" sustained stress in the allowable stress calculation.
Generally, as computing power has come a long way, industries/clients have allowed you to use the calculated sustained stress values (liberal allowable as Caesar II calls it) to be more accurate and give you more flexibility.
I certainly came of age with the default "conservative" allowable stress mentality. For the most part, we still keep it as the default for the first pass. For many systems, pipe stress isn't the limiting factor anyway. Nozzle loads and structural loading tend to be the real limits.
I will authorize the "liberal" allowables when we have a good understanding of a system and invoking them avoids an expensive redesign. I actually tend to be pretty liberal these days with approving liberal allowables.
