meanderngineer
Hello Everyone,
I was wondering if anyone had any experience regarding the benefits of using a shaft to rotate a device. Basically, I have a probe that is oriented vertically and that will be moving over a device; you can visualize this as if it were a plain and vertically oriented cylinder. If we assume the cylinder is of perfect form, I want to rotate it so that it's vertical axis will not adopt any angle during the movement. I was wondering if using a continuous rotation servo in conjunction with a shaft / bearings held any significant advantages over attaching the probe directly to the servo. I imagine the bearings would add additional constraints to the rotational motion and may increase stability, but if I use a motor with internal bearings this may be redundant / unnecessary. There will be no significant radial, axial, or torquing forces applied to the cylindrical probe, it does all of its work without making physical contact to the devices it tests.
