When changing units, model disappears
navyhill
When I try to change the units (i.e. the default units are mm and I want to change it to inches) on an imported iges, or step file, the model disappears. I tried redrawing/regenerating and nothing. Anyone have any ideas?
Thanks in advance.
Oh, by the way, WF 4.0 and WF 5.0 both are doing the same thing.
try to change the units in 1:1 ratio & do a model check.
If model tree consists of the features then it should be visible....try & check ur visibility settings in view mode.....
I am having the same problem. Navyhill, did you find a solution?
I tried doing the 1:1 unit change and that didn't solve it either. It doesn't have any features in the model tree because it is only when importing an iges or step file that I have this problem. I will look into the visibility settings. I haven't found a work around yet.
Are you using the same configuration file for both installs of WF4 and WF5? Could it be a configuration setting? Only asking because I do that frequently (mm to inch on iges and step) without any problems and it has been working on WF3 through WF5.
Just a thought and hopefully it works out.
- J -
I believe I am using the same config file, but the problem is I had the same problem with WF 4.0 and now with WF 5.0. I tried to attach a file of a part that does it. I don't have trouble with every iges or step, just certain ones and this is one of them. So feel free to play with it and let me know if it gives you the same troubles. Thanks.
 http://files.engineering.com/getfile.aspx?folder=f2b37ba6-1dc2-47d8-b422-1c04b7ac257a&file=micro_usb.prt.1
Wow, that seems to work. I sure don't know why but I will take it. Thank you so much for playing with this problem.
