what's "package" talking about here?
arishoda
Automotive
Jan 7, 2010
17
HEY,everyone here,i havnt been here for a long time,are all of you fine?
Recently,i read the book"chassis system design methodology".In the book,One sentence goes like this:"The overall design of suspension systems is mainly driven by several key factors, including handling, ride,package, cost and durability."The "package" confuses me,does it mean assembly technique or other concept? Could anyone make a explaination for me? Thank you in advance.
Package means the complete deal or all that is contained in something or all that needs to be considered in the design.
Pat
for site rules
I'd venture a guess that it's meant to be "packaging" i.e. the space required...
If you mean "packaging", that's the process of getting the parts you chose to perform all of those other functions, and all of the associated electrical and fluid lines that support them, plus the passenger and cargo volumes to all physically fit and be at least reasonably constructable. Ideally, the end result would also be easily serviceable for all components.
Sometimes the same space is "ideal" for more than one item, if you only look at each of them in isolation from the rest. At this point you have to assign priority to one and move the other(s). Repeat as necessary. Consider the compromises that might occur as you try to fit the exhaust system, chassis structure, rear suspension, fuel tank, and spare tire well all together while still providing as much useful trunk volume as possible.
Norm
Norm has it, it is jargon. The packaging group put together the basic volumes in the car, so for suspension they'll decide wheel sizes, cut angles, wheel travels and so on. This will have to miss the bodywork, and give the right approach angles and so on.
Then vehicle dynamics come along and say we can't do this, and that is silly, and we need this. Then styling come along and add their 2 cents. Assembly then point out that in fact the subframe that's been sketched won't fit on a pallet. Crash tell us we can't possibly use a rigid subframe. NVH tell us we can't possibly have a compliant subframe. So we all bitch and moan and model and pout and argue and simulate and eventually compromises are reached. That's why having a Chapman or an Issigonis is quicker.
Typical realistic constraints imposed by packaging control placement of the steering rack and routing of the steering column, at the front, and rather more at the rear, depending on architecture.
Cheers
Greg Locock
Random example.
Trailing arms with a twist-beam axle connecting the two sides, "packages" very well into the back end of a front-wheel-drive car, and millions of cars are built this way.
It would also conceptually work with rear engine rear drive, although it might not be the best choice for handling, and given that this layout has gone out of favour, I know of no examples although the little "smart" is sorta similar. Still, conceptually, it could work.
But it won't work with front-engine rear-wheel-drive (or all-wheel-drive), because the drive shaft wants to slice right through where the axle wants to be. The all-wheel-drive variations of what is normally a front-wheel-drive chassis with a twist-beam rear axle, usually have a completely different (either fully independent, or a complete solid axle) rear suspension design so that it will work with the drive shaft.
That's a great example. The forces of evil will then counterattack and say well why not run the twistbeam behind the diff? OK, we toodle off and come back with a feasible suspension design doing that. However, they'll say, that means we can't have an exhaust, and rear crash gets worse, and we lose boot volume and spare tire well, can't you put the twistbeam in front of the diff. So we say no, that means no drivehsaft, remember? And so it goes...
Also to be honest you can get away with stuff on a non driven axle that you can't on a driven axle, so commonality is not a given even if it all fits.
Cheers
Greg Locock
