What screw is this ? 2
cpper
Computer
Mar 20, 2016
Hello :)
Do you maybe know what type of screw this one is ?
URL]
URL]
Phillips pan head.
Thread looks like it could be a sheet metal screw.
Beyond that would require at least need a Sense of scale.
Diameter & thread pitch/threads per inch wild really help.
Yep, forgot to mention that he diameter of the thread is 2mm. How can I find out if these are metric or imperial ?
Buy a stock plastic or aluminum thread gauge and see which pattern fits the threads on the screws you have in hand. Buy both a metric and an imperial gauge to be sure to accurately size them up.
Dave
Thaidavid
They are quite similar to those used in household electro, where the screw screws into a hollow plastic tube and "taps" its own thread in the soft plastic.
