What is this? 1
Thanks but it is not related to rope. Two of these are connected to a rod to allow hanging of objects.
Its a support bracket / mounting bracket, as e.g. for curtain rods.
RSVP
Or for supporting a bar rail, more likely for curtain rods though.
Support for those foot rest rails in bars?
Wardrobe rail hanging support / centre supports
As hydtools says Rail post or Stanchion.
B.E.
Anti-theft napkin ring?
-handleman, CSWP (The new, easy test)
The Perko "Guard Rail Post" is fairly sturdy, and priced accordingly.
Drapery/ curtain hardware like a "hanger" is generally not nearly so sturdy.
Handrail "stanchions" may be short or quite a bit longer.
The name depends on the application, but none of the words in common use maps to a particular style, geometry, material, or load rating with any certainty, so you can't reliably order what you want without a picture and a model number.
Mike Halloran
Pembroke Pines, FL, USA
How about "rod/ towel rail / curtain rod /kitchen utensils rail etc. hanging bracket".
The difference between the applications comes down to material of construction and strength.
For curtains it would be Zn with a flash coating and it could hold 10-20kg.
The boat rail bracket is Cr plated brass and ti will probably support more like 100-150kg.
