Bhupinder1
Another related question, is it necessary to use hot modulus to calculate the deflection? The hot gases are flowing around the tubes, and there is hot water at high pressure inside the tubes.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
121.5 Hanger Spacing
Supports for piping with the longitudinal axis in
approximately a horizontal position shall be spaced to
prevent excessive sag, bending and shear stresses in the
piping, with special consideration given where components,
such as flanges and valves, impose concentrated
loads. Where calculations are not made, suggested maximum
spacing of supports for standard and heavier steel
pipe are given in Table 121.5. Vertical supports shall be
spaced to prevent the pipe from being overstressed from
the combination of all loading effects.
119.6.4 Stresses. Calculations for the stresses shall
be based on the least cross section area of the component,
using nominal dimensions at the location under consideration.
Calculation for the reference displacement stress
range, SE, shall be based on the modulus of elasticity,
Ec, at room temperature, unless otherwise justified.
