I need your feedback about choked flow in flare headers.
I am reading a study on our flare header system at the plant made in 2009. There is a PSV that has a 12” line going into a 16” pipe then into 24” header. The study says that there will be choked flow at the end of the 16” header going into 24” header and recommends to replace that portion with 24”. The recommendation was not implemented because the plant flow went down, however, it is going to increase now.
I do not have flarenet to repeat the study and the report does not show the numbers.
What is the effect of a chocked flow at some part of the header downstream? Will this cause the vessel to be at pressures higher than the PSV setting if the back pressure is high? Can I repeat the calcs without flarenet?
