What is the difference between CFM; ICFM, ACFM & SCFM?
Kshn
IN
What is the difference between CFM; ICFM, ACFM & SCFM? for flow calculation of Air compressor?
Suggest to google the clear definitions for these terms.
I Can't Find Mum to help me.
Inlet cfm I reckon.
Cfm, ICFM, scfm, at sea level basically all the same. ACFM depends on the pressure it's quoted at. So might be the same or if quoted at say 100 psi is the actual output at that pressure.
Because this will be much lower than the others my cynical hat says vendors will quote the bigger numbers. ..
Pressure * Volume = Pressure * Volume
ACFM = Actual Cubic Feet per Minute at the operating conditions
SCFM = Standard Cubic Feet per Minute at Standard Conditions
SCFM is normally used to designate flow in terms of some base or reference pressure, temperature and relative humidity. Many standards are used, the most common being the Compressed Air & Gas Institute (CAGI) and the American Society of Mechanical Engineers (ASME) standards, which are 14.7 PSIA, 68°F and 36% relative humidity (RH). This converts to a density of 0.075 lbs/cu.ft. for air.
CFM = cubic feet per minute
ICFM = inlet cubic feet per minute into the blower
