What is preventing the scissor jacks from collapsing? 4
mousecheese
CA
Hello, I have some questions about the scissor jacks. Is it the friction between the lead screw thread and the two nuts at the front and back sides of the jack? What type of friction is helping the jack to uphold the load to a specified weight without collapsing? Is there a formula? Thanks
Free body diagrams are your friend
Free body diagrams do not answer this question. You will have to pay for the premium body diagrams.
Lead screws have a lower efficiency than a ball screw which can be used to an advantage to hold a load. Check out some of the technical information by a lead screw company such as Nook. Manual machine tools use lead screws vs. ball screws for the same reason.
Kyle
Also the heavier duty ones have counter threaded bar so that the rotational effect on the rod is balanced out, i.e. one nut is CW, the other CCW.
This means they both have bar sticking out at either end.
LittleInch, I think the point you are trying to make is incorrect. It is still only friction that prevents the screw from turning under load. All that the left/right threads do is keep the screw centered in the jack.
You're probably right now I think about it.
in the picture shown, doesn't rotation of the threaded rod change the height of the lift ?
so if the rod can't rotate ('cause, say, a pin is engaged in some structure) then the lift position is restrained.
no?
See this link:
Locking depends on both friction and thread helix angle. The critical coefficient of friction equals the tangent of the helix angle. If the coefficient of friction is greater than the critical coefficient, the thread locks the load.
Ted
