jpblomberg
- Feb 1, 2006
- 3
I have been thinking about how to optimize number of blades for a given propeller application. I realize there are many applications for them so let me narrow this down somewhat.
Case 1:
Most of the large electrical wind turbine generators have three blades. This number is arrived at probably by balancing economics and structural concerns. If the economics were not a factor (price of the blade, hub, tower etc.), then how many blades would make sense? It seems to me that with 3 blades, a majority of the air goes between the blades and doesn't have a significant effect on them. My thought is that more blades would produce higher torque but the maximum rotational speed would be reduced due to the extra blade drag. My thought is an optimum number of blades would extract the maximum amount of energy from the wind.
Case 2:
An airplane propeller. So far as I know nobody makes a 1 blade prop (which could easily be done with a counter weight). Of course and infinite number of blades, or I suppose even a hundred or thousand would just make a solid disk, which doesn't produce thrust. For the case of airplane at take off, is 1 blade best? How about 2, 3, 4, 5, 25, 100 blades? In the case if a large engine, where the rotational speed is not is not limited, but the diameter of the propeller is, what would be the optimum number of blades given a particular diameter and angular speed? What number produce the most thrust?
I realize that there are other factors that affect performance. What are your thoughts?
John
"Credo ut Intelligam" I believe in order to understand -St. Augustine
Case 1:
Case 2:
John
