The dearator not only dearates the feedwater, but it supplies liquid to the boiler feed pump BFP.
If the dearator pressure drops faster than about 1 psi/sec, then the liquid to the BFP will boil in the downcomer, and cause cavitation in the BFP suction.
Several startup events can cause the dearator pressure to drop , so to prevent that, there should be a backup supply of steam to peg the dearator . The logic for the pegging steam should be based on 2 limits: do not let the dearator pressure drop below 3 psig .AND. do not let the rate of decrease of derator pressure exceed 0.5 psi / sec.
