What Grade / Temper of Aluminum To Use
MSABOL314
3
I have a cylindrical shaped part designed. The design criteria is reduced weight, increased wear resistance on the OD, and strength is not a concern. The dimensions of that part are:
OD = 4.764" +/- .005" , .001" cylindricity
ID = 4.302" +.001"/-.000" , .001" total runout to the OD
Length = 5.079" +/- .005"
The part will be electroless nickel plated, and then heat treated to increase the hardness of the nickel plating at 450 deg F for 4 hours.
My concern is that after the heat treatment the part will not be in spec (dimensionally and in form) if I shoot blindly and just use 6061-T6 Aluminum.
Ideally, I'd like to learn how to asses this problem, and be able to determine a suitable material.
Thanks in advance,
Mike
You really want to thermal cycle a piece of Al with Ni-P.
What P level? Do you care how magnetic it is?
Every type of NiP that I know uses a HT of 375-400C for 1hr.
I did find aging curves that show a response at 250C, at 35-40 WEEKS.
Wouldn't you be better off using a low P and no HT?
How are you building the cylinder? Roll and weld?
I would suggest that you rough machine and then thermal cycle, beyond the service range a few times.
And then final machine. And good luck machining something this thin and flexible to those tolerances.
Will this have solid ends in it? This will be a very flexible item.
But let's back up, what is this made from now that is too heavy?
There might be some other options.
P.E. Metallurgy
The spec was for chrome plating, but Ni-P will be a less complex process for this component. In order to get a similar hardness, the Ni-P would need to be heat treated. Initially I was quoted high P level Ni-P, but low P level Ni-P will yield higher hardness. Maybe this hardness will be sufficient.
No solid ends. This is a new design. The design criteria is to minimize the rotational inertia.
Thank you for the links.
I personally would not put many eggs in the "harder is more wear resistant" basket.
Especially armed with the info provided so far.
Your point isn't clear, but yes, harder doesn't not necessarily mean more wear resistant.
