yaston
surface finish is as explained from the previous post, is determined from the application, function of the part.
eg: seal surface, bearing surface, gear surface.
most drawing's I have seen specify Ra micro finish. which depending on the type of part & size, will determine the method of inspection.
for my application, small fine pitch gears, most surface finish are measured with a profilometer. as noted by others.
test blocks can be used to calibrate & test the profilometer.
I would like to add that micro finish specified can & will dictate the manufacturing method.
if the surface finish specified is an 4 micro or better, the the supplier will have to use the right tools to obtain it.
use tight surface finish only, and only when it is required, or the cost of the parts will increase.
Normally a 63-125 is adequate for most applications. and I would consider a smooth finish.
in my world of machined, case harden gears, & shafts, a 250 micro finish is a rough surface. 125 or 63 micro finish is normally standard.
for my type of work. however the same parts can & do mix in different micro finish call outs.
gear profile can be between 4-32 micro, journals can be 4-32 micro surface finish, non functioning areas can be 32-125 micro.
some surfaces can be 2-4 light bands, for flatness & micro combined.
I have given example of different specified surface finishes.
HTH
Mfgenggear
if it can be built it can be calculated.
if it can be calculated it can be built.
