I'm curious as to the different practices used to establish the content of equipment mounting shim packs. The go-to-guy here on the subject offered the following advice:
0.250-inch total made up of
qty. 1 of 0.125-inch SS plate
qty. 4 of 0.020-inch SS shim material
qty. 3 of 0.010-inch SS shim material
qty. 3 of 0.005-inch SS shim material
API RP 686 doesn't go into that detail but has this to say:
5 shims max. under each equipment support foot
at least 3 0.125-inch shims under each support foot
0.500-inch maximum shim stack height
only 1 0.125 or thicker shim per mounting foot
minimum shim thickness of 0.002-inches
Another source...
minimum shim thickness of 0.005-inches
qty. 1 of 0.062-inch SS shim material
qty. 1 of 0.031-inch SS shim material
qty. 1 of 0.025-inch SS shim material
qty. 2 of 0.015-inch SS shim material
qty. 2 of 0.010-inch SS shim material
qty. 2 of 0.005-inch SS shim material
Anyone know of good reference material?
My applications are with reciprocating compressors driven by industrial gas engines or motors.
Another source...
